pictures!
dougler
Post by dougler »
hmmm thanks a lot again, great info. i will get my engine re ringed then. should i get my cylinder drilled and get the over sized rings or stick with the standard?? have you done this yet to your car? what engine do you have?
If you have a B21A1, don't get your cylinders honed. B21A1 cylinder walls are made of a material called FRM (fibre reinforced metal) that is super tough and does not need honing. Some people have said that they have still been able to see the factory cross hatching in their FRM sleeved engines after 200000 kms.
If on the other hand, you have a B20A5, and you're going to really take the block apart, honing might be a good idea. You should stick with the normal sized rings unless you bore things out most likely.
My car has a B21, and I'm in the process of rebuilding a B20A5. Haven't gotten to the rings yet though. Everything is still in a million pieces.
dougler
Post by dougler »
yah i have a b21a1. i think the FRM sleeves must have just eaten away at the rings over the years as it seems to be burning oil. oh well just another job on the to do list,
Yes, FRM is hard on rings. In the long run, this is a good thing because your cylinder walls will never need rehoning. It's easy to change out rings compared to fixing wrecked cylinder walls.
CADster
Re: pictures!
Post by CADster »
dougler wrote:hey guys.. thought id let you check out my ride.. id like to see other preludes as well for some ideas, so if you got pics post em up here!
this is a 88/89 prelude with a 90/91 front bumper.
the rear is 88/89 and all the trim (except for the front bumper) is 88/89
even the rear bumper is a 88/89 bumper (notice the 90/91 rear splash gears do not line up with the 88/89 bumper exact)
