I am trying to remove the condenser fan on a 90 Prelude 2.0 SI but the A/C discharge hose above the fan shroud is in the way.
I tried to loosen the radiator and the condenser and pull both forward to make some room but it is really tight.
What is the proper way to remove the fan Assembly?
Condenser Fan Removal?
Re: Condenser Fan Removal?
That's a tricky one.
As I recall from taking one apart before, you do actually have to move some of the hoses out of the way to get the fan out. The hoses are very stiff, so it's not easy to do. Is it possible to remove the shroud itself and then slip the fan out from behind?
