BOLT-ONs
I/E/H :
Skunk2 Pro H series intake manifold
Skunk2 70mm Throttle body
Hytech Replica Headers (Tri-y 4-2-1)
2.5 inch" from header to exhaust
Highflow cat
Apexi exhaust system.
Cold air intake
Drivetrain:
Clutch masters Fx 200/300 stage 2 clutch system
Clutch masters billet aluminum Flywheel
ENGINE:
Cams:
Skunk2 pro 1 cams (Intake: duration 255, Lift 0.475)(Exhaust: duration 255, Lift 0.436)
Skunk2 adjustable cam gears
Valvetrain:
Skunk2 valve set
Skunk2 Titanium retainers
Skunk2 Spring set
Skunk2 Spring base kit
Fuel:
Venom injectors (still researching the most effective injectors for this build)
stock fuel pump
And I was THINKING of going with the almighty type S pistons, as I hear with the upgraded compression they really "bring out the color of your cams" so to speak, lol. But it seems like quite an expense for a minor increase in power.
My question is this. I'm not a big time car mechanic, but i'm not a retard either, how plausible is this build for a daily driver with the occasional street race here and there, is there anything a more professional engine builder would decide to use as opposed to what i have chosen, is there anything that should be added that i might have overlooked, also, what fuel injectors do you think would do justice to this set-up as is? basically, any feedback is welcome, would like to understand the full picture before i go on the "big shop"
thanks for your support
J
heres my sweetie
few knicks and knacks
