Replacing By-Pass hose on IAC Valve
olivernon
Is there any known technique to replace the by-pass hose from the IAC valve to the intake manifold without removal of the manifold? Thanks, i'm desperate ...its leaking out of the wazoo
hose replace
Actually, after looking at it, you should NOT have to remove the intake to replace that hose. It's a simple end to end connection and the ends are quite accessible. Unless you're looking at a different hose? Could that be the case?
Josh
Josh
