I am about to buy a 91 honda prelude si and I have a ?
kyle9999
Post by kyle9999 »
The car i am about to buy has an issue. The owner of the car Just rebuilt the slave cylinder on this car and has bled the line thouroughly.Here is the issue the clutch will not disengage can someone please help me and if so can you give me a list of things i can try before i do a complete rebuild. The clutch does not slip when it is engaged.I should also tell you that it has a 2.0l motor.
Re: I am about to buy a 91 honda prelude si and I have a ?
If the clutch won't disengage, there must be a problem with the clutch pedal syste at some point. Make sure that the lines have been bled completely and that the master and slave clutch cylinders are functioning correctly. Remember, in order for the clutch to work properly there can be absolutely NO air in the clutch line.
