Im trying to install Field SFC to my lude but im running short on the function of a few wires. I have search all over the net to try to sort out the wiring for this slightly dated vtec controller
I have used several sources to obtain what I have so far which is:
(Note: these are the coloured wires that originate from the Field SFC vtec controller's harness)
Black- Ground
White&green- VTM-ECU side
Orange- Map-ECU side
Brown- Map- sensor side
Yellow- Vtec- ECU side
Dark Blue- Vtec sensor
Green- Taps into ICM on the ECU harness, RPM signal
Red - Taps into IGP1 on the ECU harness, Ignition Power
Purple- VSS- ECU side
Light Blue- VSS- sensor side
I still need to find the function of:
Pink-
White&red-
Gray-
White-
If you know the function of any of them it would be great
Thanks for your time
