Seat Belts and other loose items...
elroto
Prelude Model: 1991 Si
Post by elroto »
Hello all fellow ludeheads,
The drivers seat belt is not retracting once I unbuckle. Is this a spring wound pull up motor or electric? I noticed that the fuse panel has a fuse for seatbelts? Is this just for the safety sensor? Thanks ahead for any thoughts or help! :D
Jose
Re: Seat Belts and other loose items...
Hi Jose,
The fuse is probably for the seatbelt sensor, there isn't a motor on your seat belt mechanism. The seatbelt retracts thanks to a spring system. It's very possible that your seat belt spring is clogged up with hair/dust/grime and just isn't functioning smoothly. I think you can take the plastic trim off the seatbelt spool and see what's what.
frank444
Post by frank444 »
Honda will fix it for free
there is a lifetime recall for the seatbelts in these cars
check it out http://mustardcat.brinkster.net/p3g/Com ... ybelts.pdf
