this guy is all about the tremclad.
here's the link, theres a bunch more posts and info in the next pages
http://board.moparts.org/ubbthreads...part=1&vc=1
IN THE WORDS OF ANOTHER:
here's how i painted my car for about $50, it's actually very easy and the results are amazing. First off, get a can of tremclad real orange (or what ever color u want) in the can, not spray, yes tremclad, it is a acrylic/enamel paint which is very durable. next prep your car as if was any other paint job, fix all the rust, ect....no need to prime the car since the tremclad allready contains elements which allow it to be painted over bare metal. next, after prepping the car get a small 4 professional FOAM rollers, it's tiny and has one end rounded off, and the other cut straight, and is a very high density foam. u also need a jug of mineral spirits to thin the paint. The thing i really like about this is that there's no mess, no tapeing the whole car, just key areas, and u can do it in your garage, since your not spraying there is virtually no dust in the air, just clean your garage first, also it does'nt really smell at all, dries overnight and it super tough paint. also it you decide to paint the car professionally later, just prep and paint, there's no need to strip the tremclad. i have done this to a few cars, and i can say it works amazing, u just have to be paitient. next u thin the paint with mineral spirits so it just about as thin as water, a little thicker. get out the roller and paint away, don't get the paint shaked when u buy it, enamel is stirred, otherwise you'll have bubbles in the paint for a week!!! after u do 2 coats, wet sand the whole car, then repeat, 2 coats, wetsand, 2 coats wetsand. i painted the charger using a can since your not spraying the car u use all the paint and not spray 50% in the air, use progressivly finer sand paper each time. it's not really that much work, cause u can stop and start any time, u can do just a door, or the hood, ect. do one panel at a time, and don't stop once you start. once your done the final coat, wetsand with about 1000 grit to a totally smooth finish, and then using a high speed polisher i use a buffing bonnet and turtle wax polishing compound. do the whole car with this, and i'm telling u, depending on the amount of time and paitence you have, the results are amazing. laugh if you want, but for $50 ($30 for paint, about $20 for rollers, sand paper, ect...) it really looks good. also you can do these steps overnight, paint one evening and by morning u can wet sand. i have personally done alot of painting, mostly single stage acrylic enamel, and i've sprayed several cars in my garage with really good professional results, just it stinks, it's a real pain to do, easy to make a mistake, messy, and expensive. The tremclad is awesome paint, the
eal orange is an amazing hemi orange, and almost looks like it has some perl in the sun, awesome color right out of the can. I used this technique on my 1974 beetle also, here are the results:
http://i32.photobucket.com/albums/d...n/Picture10.jpg
the car before:
http://i32.photobucket.com/albums/d...in/IM000475.jpg
another after pic:
http://i32.photobucket.com/albums/d...in/DSC00164.jpg
here is a car i sprayed (71 beetle, midnight blue metalic):
http://i32.photobucket.com/albums/d...in/DSC00194.jpg
here is the car before (71 beetle):
http://i32.photobucket.com/albums/d...in/Picture1.jpg
here's a few pics of the charger done:
http://i32.photobucket.com/albums/d...in/DSC02764.jpg
http://i32.photobucket.com/albums/d...in/DSC02769.jpg
well that's my 2 cents worth, sorry for the long post. i was borred lol
i painted the orange beetle in 1999, and it still looks like the day i painted it, the 71 blue beetle i painted in 2000, and built the car for my dad, i used the same paint on my charger, maybe one day i'll spring for a good paint job, prepping is 90% of the work, stripping the car, sanding, ect.....painting is overrated!!!
So if you have TIME, then i'd say go for it, the worst that could happen is that it does'nt turn out and your out $50, but if your paitient, and expriement with lets say just the trunk pannel and if you like it do the whole car, if not just get it done by someone else for $4000.
50$ Paint Job
Phukaduck
Phuk...I'm not getting anything from your links? What's up with that? I wanna SEE ! HELP! Fix it !
Josh
totally off topic.......but when I saw the concept for the new Challenger, first I hollahed out loud THE GUYS AT DODGE TOTALLY GET IT! THEY REALLY KNOW WHAT THEY'RE DOING! (yeah, I know, and I work for Honda) BUT...that's a hot car, looks like the original and Dodge is great about staying true to their concept cars....I WILL be buying one if they look like that. I will! I LOVE that orange color!
(in order to not hijack Phuk's post, I have put the Charger link in a sepearte post in the Just For Fun section of the site)
Josh
