Car has trouble starting
af_ff2008
Hello, im new with preludes but not hondas. i have a 97 Vtec. Everytime i got to start it, it doesnt turn over. after about 20-30 mintues it wil start but it sputters before it starts. Does anyone have an idea what it could be.
Re: Car has trouble starting
Does this problem get worse or better depending on whether the engine is hot or cold?
af_ff2008
in the mornings is the worst time for it. durning the day its not as bad
af_ff2008
whens its cold its terrible
Is the car throwing any Check Engine Light (CEL) codes?
There are directions here: viewtopic.php?f=2&t=318
af_ff2008
The check isnt on and that what worries me. i replaced the spark plugs but i think its the injectors
Did you say that it doesn't turn over? That sounds more like a problem with the starter to me.
af_ff2008
no it turns over. as soon as it turns over it sputters
In that case, yes, the injectors could cause trouble. Have you tried running some injector cleaner through the car. That's usually a good first step.
af_ff2008
yes and it didnt do anything.
Can you confirm that the spark plugs and timing are good as well?
af_ff2008
yes i replaced the spark plugs and had the timing checked
Well, you have spark then.
As long as there isn't a sensory problem preventing air from getting to the engine, then the fuel system is probably to blame.
There's a lot that can go wrong, but your problems are likely caused by either the injectors or the fuel pump. You didn't mention any trouble once the car gets going, so it must just be an injector problem when starting. I believe the manual has some instructions on how to do some diagnostics on the injectors. See the manuals section.
af_ff2008
