92 Si F22B will not idle when warm
92ludesi
OK i have a JDM swapped F22B block on the DOHC setup. Car runs great till the temp gets to norm op temp. After that any time you come off the throttle the car stalls, and is hard to start. Have to hold accell down to keep it running. Timing is dead on, and no vacuum leaks or coolant leaks. Just did tune up with new plugs, dizzy, oil etc... Took the EGR, FITV, and IACV valves off and cleaned them thoughly. Still no help
Re: 92 Si F22B will not idle when warm
I'm guessing that the coolant temperature sensor might be to blame, but you should check to see if the ECU is throwing any error codes first.
Here's how: viewtopic.php?f=3&t=14
Let us know what you find.
92ludesi
was the thermo valve under the throttle body. spring was tightened all the way, but where the water comes thru was dirty and nasty. fixed thnx
