I just went out and had her idle for about three minutes to see what she was going to do, and about 20 seconds after she ran the battery light turned on and then I turned on the blinker and it would turn off when the blinker would flash on. So I turned on the brights and the battery light turned off, then it would turn back on after turning the brights off. It seems like whenever there is a electrical load on the engine, the rpm's go up a little (just a little) and the battery light turns off, at least that is what it just did. Once again there doesn't seem to be a pattern to the light coming on and going off and I expect something different when I drive it later on tonight.
Also I got a little volt meter thing that plugs into my cig-lighter that displays the volts while the car is running. After letting her idle for about 3 minutes its showing 16.1 volts. I know that electrical stuff is hard to diagnose sometimes, but any help or suggestions would be nice.
Next Issue
I think that my AC pump (sorry haven't looked at the technical term yet) it starting to go out on me. Here are my reasons, today while driving around my AC would stop blowing cooled air, and it was just blowing hot. Sometimes it would return to blowing cold air but then it would die off and blow hot air. When I got home I listened to the engine and noticed a lot of noise coming from (what I believe to be the AC pump, its located just below the Alternator). Any suggestions?
Last Issue (for now)
When the AC was coming in and out, I noticed that the air seemed to blow in accordance to the engine speed. Harder when I was at a higher RPM and then when I dropped the RPM's it wouldn't blow as hard. It would do this no matter the setting I had it on, on the inside. I don't remember it ever doing this before. Whenever I would turn the AC on there would be an increase in vibration thought the car (another issue) but I never noticed any difference in how hard the air flowed.
More Issues to come!
