lost in electrical
lost in electrical
From the beginning. 92 prelude s 2.2 its my daughters car . Was stolen at chico state univ.3 weeks later was recovered and had been driven had .slight idle problem and was overheating . I fixed that to have water pump go out . I replaced that the timing belt balancer belt. Then the car would randomly die . Turn the key off and back on and it would start back up and run fine . This problem got increasingly worse.the flashing code was15 . Instead of trying to just replace the igniter, I replaced the entire distributer. Now the car won't even start. There is no sound from fuel pump and no spark from coil. Please help.redisrite
Re: lost in electrical
Simple things first:
Are all your fuses good?
Yes I since replac d distributer and now I have no spark from coil. There is power going in
Are you still getting no sound from the fuel pump?
Have a look at this thread: viewtopic.php?f=3&t=608
The main relays can go bad on 4th gen Preludes and cause some of the issues you're having.
Are you still just getting CEL code 15, or are there others now?
