bouncing idle problem and wondering stearing
Hello im new to preludes and was wondering if anyone knows how to fix the bouncing idle problem. My stearing also wonders back and forth just wondering if anyone had and ideas on that as well. ty
Re: bouncing idle problem and wondering stearing
Hi
The Idle problem most likely the Air control valve.
her is the fix
http://92lude.com/idle_air_control_bypass_mod.htm
her is the fix
Regarding the wandering steering, can you more accurately describe what the car is doing? Is the car pulling from side to side or does the steering wheel just feel loose in your hands?
the steering is solid its just pulling from one side to the other
I'd start by getting your alignment checked. Something is causing the car to track along the road poorly. You can't really adjust the caster on a Prelude, and unless the car has been lowered, your camber is probably fine, so perhaps the toe is out.
Either that or your ball joints or stabilizer bars are loose and the suspension system is roaming around a bit under the car causing it to wander.
sweet thanks for the info guys ill get back to you and let you guys know if it worked out all right
hay guys so i checked my ball joints and they seem to be fine, i havent gotten a weel allignment yet but when i was working on my ball joints i noticed that my whole CV boot and the underside of the skid plate is covered in oil and im not shure where its coming from any ideas ty
If it's the inner CV joint, you axle seals are probably leaking and the oil you see is oil from the transmission. If it's an outer cv joint, that 'oil' is probably the bearing grease from inside the CV boot. If your CV boots are torn you'll need to get those fixed.
