oil pump
oil pump
I beleave my oil pump, or the seal of the gear shaft of the oil pump in the . .timing belt loop is leaking. I would beleave that I can replace the outer part of this pump and gear drive without changing the pick up in the oil pan, or removing the oil pan. If any one has any tips or input on this it would be appreciated
Re: oil pump
Sounds like your crank seal on the timing belt side of the engine is leaking. It is possible to replace these, but the procedure will be fairly intensive. Are you quite comfortable with mechanics?
Re: oil pump
I have removed the cover and it doesn't seem to be the front main, I noticed more dirt and oil around the oil drive. I am putting the pulley and belts back on tonight and going to watch as to where the oil is coming from.
Re: oil pump
Yep, front seal, reinstalling the timing belt was testing my nerves. Other than that it was pretty simple
Re: oil pump
No more leaks. I had to put a ring of silicon around the outside of the seal. The seal I found had pushed out into the tinning belt Gide washer. I siliconed the outside of the seal to try and keep in to stay in. Driving 900 miles back home tomorrow so hopefully I don't run into issues
