1997 prelude with h22a on obd1 nopower
I have a 97 lude with a h22a swapin in with obd1 convertion. its using the td60u distribuator and the p13 ecu. i have checked time both mechanical and electronic and both are ok, also i have no cel codes. What happens is the car starts and idles fine but when you goto drive it is gutless. any ideas any help will be nice i have no idea about the jumper harness stuff
Re: 1997 prelude with h22a on obd1 nopower
Are you sure the timing is set correctly? If the engine runs, but doesn't make any power, I'd suspect a timing problem, or perhaps the TPS sensor.
