the Cyl sensor is near the oil pan.
the crank sensor is near which one?
Where do i find the other one. so can get car inspected?
thanks
codes
Re: codes
Crank sensor is generally near the main crankshaft pulley. You should see a wire leading to it.
Re: codes
on the dohc the 2.1 the distributer is run off the intake side cam, and the exhaust side cam (front) drives where the switches (sensors) are in that housing. and oddly enough that's where the sensors were. it was unplugged and now the engine light went off. so now got to reset the computer. DO you just pull the battery cable? this is defienetly learn as u go method.
Re: codes
Easiest way to reset the ECU is to just pull its fuse. The fust is located in the fuse box under the hood next to the battery.
