1992 - 1996 Honda Prelude Engine Specifications
S Model
Designation: F22A1
Type: In-line 4 cylinder, aluminum block and head
Bore & Stroke: 85.0 x 95.0 mm (3.35 x 3.74 in)
Displacement: 2156 CC (132 cu in)
Compression Ratio: 8.8:1
Engine Control System:
Honda Systems PGM-FI with port fuel injection
EmissionControl:
Three way catalytic converter, feedback fuel-air ration control, EGR system
Valve Gear: Belt-driven, single overhead cam, 4 valves per cylinder
Power (SAE net): 135 BHP @ 5200 rpm
Torque (SAE net): 142 lb-ft @4000 rpm
Redline: N/A
Si Model (2ws)
Designation: H23A1
Bore & Stroke: 87.0 x 95.0 mm (3.43 x 3.74 in)
Displacement: 2259cc (138 cu. in.)
Compression Ratio: 9.8:1
EmissionControl:
Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
Power (SAE net): 160 bhp @ 5800 rpm
Torque (SAE net): 156 lb-ft @ 5300 rpm
Redline: 6500 rpm
VTEC Si Model
Designation: H22A1
Bore & Stroke: 87.0 x 90.7 mm (3.43 x 3.57 in)
Displacement: 2157cc (132 cu. in.)
Compression Ratio: 10.0:1
Emission Control:
Valve Gear:
Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift
Power (SAE net): 190 bhp @ 6800 rpm
Torque (SAE net): 158 lb-ft @ 5500 rpm
Redline: 7500 rpm
4th Gen Engine Specs
