3rd Generation Engine Symptom Chart & ECU Error Codes
Postby spiffyguido » Sat Mar 13, 2010 2:39 pm
ludelover91
Re: 3rd Generation Engine Symptom Chart & ECU Error Codes
Postby ludelover91 » Thu Jun 17, 2010 10:21 pm
hi see your code(s). how do you get the codes to figure out why engine lite is on? How can i pull the code out.
Postby spiffyguido » Thu Jun 17, 2010 10:34 pm
There is a flap in the carpet of the passenger side footwell. If you lift it up you can see the error code light on the ECU blinking. Just count the number of flashes to get the code. If there is more than one code being thrown, there will be a long pause between sets of flashes. Some ECUs use long flashes to represent 10, i.e. two long flashes followed by three short flashes would mean 23.
ludelover91
Postby ludelover91 » Fri Jun 18, 2010 10:44 am
thank you so much. this site has been ALOT of help. thank ya
ludelover91
Postby ludelover91 » Sat Jun 19, 2010 8:44 pm
hi,
ok looked at the emc the led on the left blinks 4 times. the led on the right blinks 9 times. it keeps blinkn the same number. any help would be appreciated. thanks
Postby spiffyguido » Tue Jun 22, 2010 12:07 pm
9 blinks is the cyl sensor.
Have a look at the images attached to the opening post of this this topic. Do any of the symptoms listed occur in your car?
ludelover91
Postby ludelover91 » Tue Jun 22, 2010 6:05 pm
yes just took a look and the 9 is Cyl and the 4 blinks is the tdc/crank i guess. thanks for your help.
newluder91
Postby newluder91 » Wed Jul 11, 2012 8:51 pm
what does it mean if the light stays on?
Postby spiffyguido » Thu Jul 12, 2012 11:29 am
The light on the ECU or the check engine light?
Users browsing this forum: No registered users and 6 guests
