name and duty of this part?
potatoskinz
Im guessing I have a gasket problem as I had lits of oil caked around it but I am unsure what the part is or does . Thanks
Re: name and duty of this part?
That's the CYL sensor.
If it is the source of a leak, it may be due to an O-ring that is inside. I believe the entire CYL sensor unit is a discontinued part, but I bet Honda would still carry the O-ring as these are likely to wear out with age.
Never done it, but it's probably not hard to repair.
nimec
Hello, remove the sensor from oil and dry .After that Spread sealant, wait a bit and twisted into place. It is not hard-key for 10mm and Sealant (we use Ukraine Viktor Raines). sori- translator chrome.
