89 Prelude SI VSS
crbranon
89 Prelude SI VSS
Postby crbranon » Mon Jul 21, 2014 4:11 pm
Check engine light came on.The speed sensor code (#17) has come up. What causes this and what is the fix?
Re: 89 Prelude SI VSS
Postby spiffyguido » Mon Jul 28, 2014 7:15 am
Often that problem is wiring related, or the VSS sensor itself is bad.
First place to look is to check the wiring right at the VSS. It's contained in a small metal box that is fastened to the top side of your transmission, near the firewall. You'll see the wires. Check for breakage or disconnections.
Users browsing this forum: No registered users and 5 guests
