88 Prelude Speedo not working
andrewc1968
Postby andrewc1968 » Thu Jun 05, 2014 9:14 pm
Hi Im new to the forum and have recently purchased an 88 prelude
The odometer is working but the speedo is not. It was working when i purchased the car but it has just stopped operating
Does anyone have any ideas on how to fix this
Re: 88 Prelude Speedo not working
Postby spiffyguido » Fri Jun 13, 2014 1:21 pm
Check the speedo cable. I believe on the 88 Preludes a speedometer cable is still used. It will run from the firewall down into the top side of the transmission and may be retained by a small metal clip. These can fall off sometimes.
If instead of a cable you have a VSS sending unit (small metal box on top of transmission), check the wiring.
andrewc1968
Postby andrewc1968 » Sun Jun 15, 2014 6:22 am
The speedo cable is connected fine as it is still driving the odometer
There is an electronic connection between that and the Speedo that i am not sure is functioning correctly
I have taken another dash out of a car at a wreckers and had it checked to be sure its Ok before i install
Thanks for the answer anyway
Users browsing this forum: No registered users and 7 guests
