Let's Talk Brake Fluid
A forum to post write-ups and how-tos for Honda Preludes.
How often do you change your brake fluid ?
Every Year
4
67%
Every Few Years
1
17%
What's Brake Fluid?
1
17%
Total votes: 6
Postby RedRacer » Mon Jan 30, 2006 5:19 pm
Brake fluid. Most people just know that it has to be checked and that it should never get low. They don't know that it should be flushed annually for most average store bought brands, nor are most people aware of the many variances and differences in brake fluids and types.
First, you need to understand wet and dry boiling points and how they impact your ability to stop safely
The amount of moisture in brake fluid definitely affects its performance. The big problem is it absorbs moisture quickly. Over a relatively short period of time brake fluid will absorb moisture from the air. SAE field tests have shown that the average one year old car has 2% moisture in the fluid. A random test of vehicles in the U.S. showed an average water content of 2.6% for vehicles with an average age of 8 years. And 25% of these vehicles had water content greater than 4%. That's really amazing AND scary to me! I drive on the same roads with most of these people....and so do YOU! You may even be one of them, RIGHT NOW!
As water content in brake fluid increases over time, the boiling point decreases. Fluid with a reduced boiling point (or high water content) can create vapor by boiling in the caliper, or wheel cylinder. The result is sudden brake failure. And water in the brake fluid can contribute to corrosion of parts such as steel pistons and ABS modulators.
The end result is, even though DOT 3 fluid is rated at greater than 401' F, in the typical 3 to 4 year old car with 3 to 4% moisture content, it could boil at temps under 300' F! If you have more than 4% moisture content in your brake fluid, well, you may as well be running straight water in the lines! YIKES! Can you say CRAAASH?!
Let's look at the DOT ratings. The table below shows the MINIMUM wet and dry boiling points for DOT 2, 3, 4, 5 and 5.1 brake fluid in degrees Fahrenheit.
DOT 2 Dry Boiling point **
DOT 2 Wet boiling point **
DOT 3 Dry Boiling point 401
DOT 3 Wet Boiling Point 284
DOT 4 Dry Boiling Point 446
DOT 4 Wet Boiling Point 311
DOT 5 Dry Boiling Point 500
DOT 5 Wet Boiling Point 356
DOT 5.1 Dry Boiling Point 270
DOT 5.1 Wet Boiling Point 190
The **DOT 2 spec is for drum brakes and is obsolete. If you have any DOT 2 in your garage, throw it away! DOT 5 is for silicone brake fluid. Silicone brake fluid (DOT 5) should be avoided because it is not compatible with regular brake fluid, it is hard to pour without introducing bubbles and thus results in soft pedal feel, and moisture still gets into your system and will pool in low areas like your calipers and encourage rapid corrosion. STAY AWAY!
DOT 5.1 is a polyethylene glycol-based fluid (contrasted with DOT 5 which is silicone-based). Polyethylene glycol fluids are hygroscopic and will absorb water from the atmosphere, which is necessary to prevent sheer and undiluted water in the braking system, which is very corrosive. *As of 2006 most cars produced in the U.S. use DOT 4 brake fluid.
That leaves DOT 3 and DOT 4 fluids. These fluids are compatible with each other and may be interchanged or mixed with no ill effects.
Let's look at some popular brake fluid brands/types and their boiling points: * boiling temps are Fahrenheit
Castrol LMA DOT 3 and 4
Dry - 446 Wet - 311
Ford Heavy Duty DOT 3
Dry- 550 Wet - 290
ATE Super Blue Racing
Dry - 536 Wet - 392
ATE TYP 200
Dry - 536 Wet - 392
Motul Racing 600
Dry - 585 Wet - 421
Castrol SRF
Dry - 590 Wet - 518
Performance Friction
Dry - 550 Wet - 284
Castrol LMA is very good at rejecting moisture and may be kept in your brake system for a couple years. The LMA stands for Low Moisture Activity. This is the minimum quality stuff that I would use in my Grandma's Impala SS. It comes in plastic containers which do not have a long shelf life. Don't buy lots of this stuff at a time because moisture can make its way through the plastic containers. About 8 or 9 dollars a bottle.
Ford Heavy Duty DOT 3 is VERY inexpensive and is popular among racers because of its excellent dry boiling point. BUT, it does absorb moisture quickly, but the racers don't care since they change their fluid frequently. Comes in metal cans so it can be stored. I would not use this say, in my grandma's Impala SS. The car sits more than it is driven, moisture would be rampant in the system. Keep this for the racers only.
ATE Super Blue Racing and ATE TYP 200 are the same brake fluid in two different colors (blue and amber, respectively). Big advantage in using these two fluids are the colors. You can easily alternate between the two because they have the same specs, and the colors let you know when you have successfully replaced the old fluid with the new (old blue, new amber, vice versa) BMW factory recommends this brake fluid for their street cars because it, like Castrol LMA, absorbs moisture very slowly. The big advantage over LMA is that ATE has a better wet boiling point. You can put this stuff in your car and forget about it for a long time.(3 years) An excellent choice for a weekend track car which also sees regular street duty. Comes in metal cans. This is what I use in my cars, trucks and motorcycle; Prelude, G35, Titan, Tahoe and Ducati 996. Works great in all and gives very nice, firm pedals.
Motul Racing 600 is a very exotic and expensive synthetic fluid with high wet and dry boiling points. Too expensive for the street and requires frequent changing due to its hygroscopic nature. Sold in plastic bottles. It is not suitable for street use because it absorbs moisture quickly.
Castrol SRF is a hyper-exotic and hyper-expensive brake fluid that is generally used by people with lots of money who run Porsches at track events. I've seen prices of $78 a liter for this stuff. Sold in metal cans. I can't afford that!
Performance Friction High Performance DOT 3 has a good dry boiling point, but a crummy wet boiling point. It comes in metal cans which is good for shelf life and sells for about $8 dollars for a 16 ounce container. If you are even considering this fluid, I would go with the cheaper Ford Heavy Duty DOT 3. With either of them, you need to change them frequently due to the poor wet boiling point.
Moral of this story is: Flush your brake fluid every year or so. But only if you would like it to work well scarcely an inch away from those toasty warm 500 degree rotors during a couple of hard or high speed stops! Or would you rather have the squishy pedal of death?
Josh
Postby spiffyguido » Mon Jan 30, 2006 10:43 pm
That's a killa writeup, Josh. Love it.
This is really important stuff. Having functional brakes is what saves your life. Change the fluid often!
I'd also like to point out that similar fluid can be found in our clutch lines (for those of us with hydraulic clutches), and it too should be changed frequently.
Thanks Josh!
-Spiff
garygadget
Postby garygadget » Mon Feb 04, 2008 5:07 am
Guilty by reason of insanity
CADster
Re: Let's Talk Brake Fluid
Postby CADster » Tue Apr 29, 2008 9:12 am
i change mine twice a year... spring and fall.
si96lude
Postby si96lude » Fri Feb 04, 2011 8:25 pm
You have convinced me. I am going to get a one man brake bleeder tomorrow and see if I can find any of the ATE fluid here in Colorado Springs. I will do my part to get the word out about this.
96 si (stock for now)
Postby RedRacer » Fri Feb 04, 2011 11:45 pm
Glad that you enjoyed the write-up. And I'm glad you commented because that made me reply which made me look over the article and realize that I need to do a little updating and cleanup on it. :) You might want to read over it again. While I didn't change much, I did go over a few updates and made it a little more "fluid" (no pun intended) in how it reads. I can't believe I posted that without proofreading it better than I did!
Since ATE Blue or TYP 200 is not a product that the average Joe buys, most parts stores don't sell it. If you feel like a ride up to Denver, Dart Auto carries it, or did. I'd call them before you make the drive, just to be sure. Not that far but with gas at 4 dollars a gallon, not a trip you want to make without knowing they have what you're going after. http://www.dartauto.com They're a really good Porsche BMW service shop in Commerce City, about 6 miles northeast of downtown Denver, past the Suncor refinery.
Have fun, and good luck.
Return to “Write-ups”
