bypassing the ABS system?
Posted: Fri Jul 30, 2010 9:49 am
by 91darkness
Hey guys,
Was wondering if anyone removed their abs system and made it a closed system.
Re: bypassing the ABS system?
Posted: Fri Jul 30, 2010 10:27 am
Don't even go there.
The ABS system is very hard to reinstall and set up if you ever wanted to put it in.
If you don't like the ABS, just pull the fuse out and carry on with life. This makes the car behave as if the system wasn't there.
Posted: Fri Jul 30, 2010 7:49 pm
by 91darkness
the problem is that i leak an amazing amount brake fluid from the system. Pressure builds up and comes right out the top of the unit. I fill up my brake fluid every couple days. the unit stopped working about about 7 months ago.
Posted: Sat Jul 31, 2010 11:47 am
The ABS system is leaking? Unplugging it should prevent it from pressurizing.
Posted: Sun Aug 01, 2010 7:32 am
by 91darkness
Ill try that, we'll see what happens.
Posted: Sun Aug 01, 2010 8:52 am
The fuse is located in the fuse box under the hood. One fuse disables the entire system.
