Stall
Posted: Sun Mar 21, 2010 9:04 pm
by Tenten
Hello All!
Okay, prior to getting the car running, I had the fuel pump replaced. I also cleaned the IAC per the DIY (thanks). So I had the local so replace a couple engine Cam Plugs or seals because THEY said it would stop my oil leaks, which by the way didn’t stop but THEY said it was due to the runoff from the oil. We shall see later...
Anyway, after I got the car back and drove it around, it stalled! It never done that before and it was idling rough. I called the shop and asked if they set the timing back wrong or something and they said they never touched the distributor. Would that be a true statement? I stopped the car and looked under the hood (do that first everyone) and the 3rd plug, not fully plugged in. I plug it in, the car felt "stronger" but it later stalled again?
What the French toast!?!
Any Advice
Ten10
Re: Stall
Posted: Thu Mar 25, 2010 2:12 pm
Now that the spark plugs are all plugged in again, does it still stall?
When does it stall? At a light? When idling? Randomly?
