Fans
Posted: Sun Mar 07, 2010 2:09 pm
by Red2010_2008
Hey The Other Day I noticed After I Shut My Car Off And The Fans Turned On, There Was A Very high Noise Coming From The Fans, It was A Squeeky Type Noise....What Could That Possibly Be? Plz Help!
It Jus started Doin it like two days ago.
Re: Fans
Posted: Sun Mar 07, 2010 3:55 pm
Sounds to me like some of the bearings in the fan might be unhappy for some reason or another. See if you can figure which fan is making the noise, then wait till it shuts off and get in there to double check it's not all gooed up with some dirt or something. It might be just really dirty.
Re: Fans
Posted: Tue Mar 16, 2010 10:23 pm
by Red2010_2008
how do i clean it? i think its the driver side fan, doesnt do it constantly, jus everyonce in a while after shutting off, then every now and then when im driving........
Re: Fans
Posted: Tue Mar 16, 2010 11:37 pm
It won't be really easy as the fan motor is probably tightly encased. Just check the casing at the center of the fan blades for any obvious signs of grime. Clean it if you can. I don't think you'd be able to take it apart to do a deeper clean, although I'm not absolutely sure as I don't have direct experience with doing such a thing.
