car bogs and dies
Posted: Thu May 16, 2013 11:15 pm
by jvilla
I went to start my car and it would not start. Finally got it to start and kept the gas pressed. After it warmed up I tried to move it and it bogs and dies. I replaced the distributor, rotor, spark plugs and fuel injectors. It ran better but when I change the gear it bogs and shakes the car back and forth. I can press the pedal all the way down and it doesnt respond. It slowly climbs up. Now I have a CEL and i jumped it for a code and all I get is 1. SO its the oxygen sensor?
Re: car bogs and dies
Posted: Fri May 17, 2013 12:54 pm
Check to make sure your oxygen sensor is connected as it should be. All that shaking might'be loosened something up.
In my experience, bogging is often caused by a bad EACV valve, or sometimes a faulty TPS sensor. When I had a bad EACV, my car would accelerate, but if I pushed the gas too hard, the engine would bog and falter and nearly stall. Worst part was, I never got an error code actually pointing at the EACV. I replaced it after exhausting many other options.
Anyway, start by getting your code 1 taken care of, then see if others result. Double check all aspects of your ignition system as well.
