1994 Prelude starting problem
Posted: Mon Nov 07, 2011 11:36 pm
by Ady
Hi all, am new to this forum but hoping someone can offer some help. My Prelude has an intermittent starting problem whereby sometimes it starts straight up and other times it cranks over but will not start. Engine light sometimes stays on but if I turn the key off and then on again, light goes off. My husband is convinced it is a fuel sensor problem but I would like some other ideas so we can set about getting it fixed. Any suggestions would be very helpful.
Re: 1994 Prelude starting problem
Posted: Mon Nov 07, 2011 11:53 pm
Hi Ady,
The engine light indicates that your ECU is throwing an error code. It would be helpful if you could find out what error is being thrown. Directions on how to do this are here:
viewtopic.php?f=3&t=14
Have you noticed any pattern as to when the car will start and when it won't. For example, does it only start easily when the engine is cold? hot?
Posted: Tue Nov 08, 2011 12:06 am
by Ady
Problem happens when engine is hot.
Posted: Tue Nov 08, 2011 12:09 am
by Ady
I will get my husband to check it out over the weekend and will let you know how we get on. Thanks for your advice.
Posted: Sat Nov 26, 2011 6:08 pm
by Ady
Turns out all sensors, relays etc were fine. Problem turned out to be dry solder. Auto electrician picked up problem and all fixed now. Thanks for your help.
Posted: Sun Nov 27, 2011 7:19 pm
Thanks for coming back to follow up with the resolution. Your experience may help others.
Posted: Mon Feb 13, 2012 2:12 am
by coolguy_fiji
Ady wrote:o electrician
where actually did the Auto Electrician pick up this fault.
i am having a similar issue with my gen 4 lude.....
thanks
Ronald
