just died while driving...
Posted: Sun Jan 20, 2008 11:53 am
Hi,
I recently did a head gasket change on my 91 2.05L prelude - and lots of thanks to those who helped answer my questions along the way.
Everything was going well for a few weeks and lots of driving both around town and on the highway. (after I re-timed it and replaced the fast idle valve)
However, the other day I was cruising at about 80kph and the car simply died. No warning lights, nothing. I did notice a little bit of 'ticking' that same day, but attributed it to the -20 temperatures outside.
Pulled the fuses to reset stuff and tried to start it again. It turns over, but won't start. It doesn't sound like there's any combustion either. I thought maybe it snapped timing belt but a quick look showed it was okay. I was gonna pull the cover off to see if maybe it slipped and the cam pulleys were off, but with no spark, I thought there might be a better place to start...
I should mention the night before I was driving home at about 120kph with no strange sounds, warning lights, or anything else that might have indicated a problem.
Does anyone have some suggestions on the direction and maybe a checklist I should begin with?
