Speedometer Stopped working
Preludedude
Prelude Model: 95' VTEC
Post by Preludedude »
I replaced my speed sensor, and re-flowed soiled and still no change its a 95 h22a1
Re: Speedometer Stopped working
Have you checked for continuity between the speed sensor and the dash?
Are you confident that the speed sensor you got works fine?
There's some info on how to test here: viewtopic.php?f=3&t=78&p=218&hilit=VSS
mordekai52
Post by mordekai52 »
I have a 95 manual prelude and Im having trouble with the needle on my milage gauge for my speedometer. Rpms work perfectly but the milage needle gets stuck. I can hear what sound like the innard gears spinning so I'm curious as to what I can and should do.
mordekai52
If you can hear the gears inside spinning but the needle doesn't move I would wonder if something is damaged within.
