Honda Prelude Parts List
Posted: Tue Oct 12, 2010 10:54 pm
Honda Prelude
ACT Clutches:
Performance Pressure Plate:
83-87, H-017, (+35%), $162.56
84-87, H-018,( +40%), $172.18
88-89, H-019, (+43%), $256.07
88-89, H-019X, (+88%), $312.89
90-91, H-020, (+43%), $277.93
90-91,H-020X, (+88%), $330.37
92-01, H-026, (+41%), $200.15
92-01, H-026X, (+95%), $270.07
Performance Street Disc:
83-87, 1.8l, HSD011, $38.46
84-87, 2.0l, HSD005S, $104.01
88-89, 2.0L, HSD004, $47.20
90-91, 2.0L, HSD015S, $138.09
92-01, All, HSD806S, $138.09
Racing Disc:
6-Puc Very Aggressive Contact, $99.20
83-87, 1.8L, 6P200K
84-87, 2.0L, 6P212K
88-89, 2.0L, 6P212L
90-91, 2.0L, 6P220J
92-01, All, 6P224J
4-Puc Brutal Contact, $82.59
83-87, 1.8L, 4P200K
84-87, 2.0L, 4P212K
88-89, 2.0L, 4P212L
90-91, 2.0L, 4P220J
92-01, All, 4P224J
Release Bearing:
84-87, RB370, $31.29
88-01, RB817, $35.83
Addco Anti-Sway Bars:
To 84, Front, 3/4", 177U, $141.75
To 84, Rear, 3/4", 326U, $141.75
85-87, Rear, 3/4", 404U, $141.75
92-96, Front, 1", 02034U, $156.45
92-96, Rear, 1", 02009U, $156.45
AEM Air Induction Systems:
Replace * with B for Blue, C for Clear/silver or R for Red
Air Bypass Valve:
92-96, 20-402s, $39.58
97-01, 20-403s, $39.58
Cold Air Induction:
92-96, 21-405*, $223.98
97-01, 21-406*, $209.85
Short Ram Induction:
92-96, 22-405*, $126.55
97-00, 22-406*, $126.55
AEM Big Rotor Brake Systems (17" rims required):
O.E. Caliper Kit:
92-96 VTEC, Front, 29-516*, $500.77
92-96 Non-VTEC, Front, 29-512*, $500.77
97-01, Front, 29-519*, $500.77
Rear, 29-625*, $505.53
Four Piston Caliper Kit:
92-96 non-VTEC, 29-828*, $1995.38
97-01, 29-825*, $TBA
AEM High Performance Brake Pads:
83-87, DX, Front, 26-100, $40.41
85-87, SI, Front, 26-105, $35.44
88-91, SE/SI, Front, 26-125, $44.33
Rear, 26-200, $39.73
92-96, S/SE/SI Non VTEC, Front, 26-145, $52.88
Rear, 26-205, $40.54
93-00, VTEC, Front, 26-120, $57.89
AEM Tru-Time Adjustable Cam Gears:
88-91 B20/B21, DOHC 23-602*, $94.90 each
92-96 F22 SOHC, 23-603*, $142.51 each
92-96 H23, 23-602*, $94.90 each
92-01 H22 VTEC, 23-601*, $142.51 each
AEM Tru-Power Pulley Kits:
92-94 S w/o AC, 23-7021*, $160.33
92-96 S/Si Non-VTEC, 23-7021*, $160.33
92-96 S/Si VTEC, 23-7022*, $160.33
97-01, 23-7022*, $160.33
AEM High Volume Fuel Systems:
*** means Adjustable Fuel Presure Regulator will fit W/AEM Fuel Rail Only
Fuel Pressure Regualtor:
89-91, Si, 25-300, $167.66
92-96, S, 25-300***, $167.66
92-01, All, 25-300***, $167.66
92.01, All, 25-303***, $167.66
High Performance Fuel Filter:
92-01, All, 25-200*, $94.82
High Volume Fuel Rail:
92-01, All, 25-104*, $132.96
APC Products: Available - email for pricing
A'PEXi Super AFC (Digital):
401-A907, $395.10
49A-A008, Harness, $22.86
A'PEXi VTEC AFC
401-A908, $413.10
49A-009, Harness, $22.86
A'PEXi Rev Speed Meter GP:
405-A012, $247.50
430-A013, G Sensor, $67.50
A'PEXi Mounting Bracket for RSM,AFC,VAFC,AVCR:
430-A006, $14.35
A'PEXi International N1 Exhaust
92-96, 162-KH06, $539.10
97-00, VTEC, 162-KH08, $539.10
97-00, Type SH, 162-KH09, $539.10
A'PEXi WS Exhaust:
97-01 VTEC, 104-KH10, $467.10
97-00 Type SH, 104-KH11, $467.10
92-96 All, 104-KH06, $458.10
A'PEXi N1 Exhaust:
97-01 VTEC, 162-KH08, $539.10
97-01 Type SH, 162-KH09, $539.10
92-96 All, 162-KH06, $539.10
A'PEXi Power Intake:
92-96, 508-H002, $107.10
ARP Fastners:
208-6401, 1.8L, 9mm, Rod Bolt Kit, $39.45
208-4304, H22A4, VTEC, Head Stud Kit, $155.99
Auto Meter Gauge Pods:
Pillar Gauge Pods:
92-96, Dual 2 1/16", 20439, $27.00
92-96, Single 2 1/16", 20440, $21.00
97-00, Dual 2 1/16", 20436, $27.00
97-00, Single 2 1/16", 20437, $21.00
B&M Short Shift adapter:
45063, $98.33
Centerforce:
Centerforce I:
79-82, 1.8L, CF340503, $162.75
83-87, 1.8L, CF340508*, $163.53
84-87, 2.0L, CF005518*, $160.26
Centerforce II:
88-89, 2.0L, CFT904004*, $392.18
90-91, 2.0L, CFT913813*, $462.17
92-01, All, CFT915015*, $271.57
Dual Friction Clutches:
79-82, All, DF503340, $254.38
83-87, 1.8l, DF508340*, $254.38
84-87, 2.0l, DF518005*, $232.94
88-89, All, DF904004*, $448.44
90-91, All, DF913813*, $528.44
92-01, All, DF915015*, $316.16
*Does not have Centerforce weights due to bell housing clearance
Clutch Masters Clutches:
Stage 1: (Moderate abuse, moderate power, 70% over stock)
83-87, 18.L, 08-006-HD00, $234.85
84-87, 2.0L, 08-008-HD00, $389.88
88-89, 2.0L, 08-013-HD00, $389.88
90-91, 2.0L, 08-029-HD00, $389.88
92-01, All, 08-014-HD00, $315.27
Stage 2: (Long life, moderate abuse, moderate power, long break in, smooth engagement, 70%)
83-87, 1.8L, 08-006-HDKV, $269.68
84-87, 2.0L, 08-008-HDKV, $439.68
88-89, 2.0L, 08-013-HDKV, $438.74
90-91, 2.0L, 08-029-HDKV, $438.74
92-01, All, 08-014-HDKV, $347.06
Stage 3: (Best Street/Strip, long life, long break in, 110% over stock)
83-87, 1.8L, 08-006-HDTZ, $377.60
84-87, 2.0L, 08-008-HDTZ, $523.76
88-89, 2.0L, 08-013-HDTZ, $523.76
92-01, All, 08-014-HDTZ, $425.82
Stage 4: (Harsh engagement, best road race, 170% over stock)
83-87, 1.8L, 08-006-HDCB, $416.19
84-87, 2.0L, 08-008-HDCB, $538.29
88-89, 2.0L, 08-013-HDCB, $538.29
90-91, 2.0L, 08-029-HDCB, $538.29
92-01, All, 08-014-HDCB, $467.82
Stage 5: (Drag only, harsh engagement, 200-400% over stock)
83-87, 1.8L, 08-006-HDB4, $298.03
84-87, 2.0L, 08-008-HDB4, $435.59
88-89, 2.0L, 08-013-HDB4, $435.59
90-91, 2.0L, 08-029-HDB4, $435.59
92-01, All, 08-014-HDB4, $328.59
Corbeau Seat Brackets:
97+, Driver Side, E1306T, Passenger Side, E1307T, $85.75 each
92-96, Driver Side, D1146T, Passenger Side, D1147T, $78.50 each
88-91, Driver Side, D936F, Passenger Side, D937F, $78.50 each
83-87, Driver Side, D836T, Passenger Side, D836T, $78.50 each
80-82, Driver Side, D282T, Passenger Side, D282T, $78.50 each
**** Go to the Manufacturers Tab and see all the Seats in the Corbeau line ****
For cars with distributors & internal coil:
Crane Fireball HI-6 Ignition and PS-91 or PS-92 Coil:
6000-6420, $202.22
730-0091, $47.79
730-0092, $68.15
(For simplified installation, add this:
6000-8950, Universal Trigger Adapter, $78.74)
(Most Japanese Imports [except Honda] also require
the 6000-8910 Tach Adapter, $31.95, if the 6000-8950
is not used for installation)
(Installation requires a simple modification of the
distributor cap. Kit & Instructions available for $7.50)
Crower Rods:
H22, VTEC, B93748B, $678.00
Cusco Strut Tower Bars:
92-96, Alluminum Shaft, Rear, 325511A, $131.10
92-96, Alluminum Shaft, Front, 325510A, $131.10
88-91, Front, SOHC, 323510A, $131.10
88-91, Front, DOHC, 324510A, $131.10
88-91, Rear, SOHC/DOHC, 323511A, $131.10
Cusco Limited Slip Differential: (must add in bound freight)
92-96, VTEC, LSD175A, $832.00
CyberMax Fuel Pressure Riser:
-SX 35-80 PSI Regulator
-Liquid-Filled Gauge
$214.95
DC Sports: (prices not current)
Ceramic Coated Headers:
84-87, SI, HHC5010, $359.95
88-89, SI, HHC5005, $359.95
90-91, SI, HHC5006, $355.45
92-96, S, HHC5007, $359.95
92-96, SI, HHC5008, $355.45
92-96, VTEC, HHC5009, $355.45
97-99, Type SH, HHC5014, $355.45
97-99, HHC5015, $355.45
Stainless Steel Headers:
84-87, SI, HHS5010, $440.95
88-89, SI, HHS5005, $440.95
90-91, SI, HHS5006, $436.45
92-96, S, HHS5007, $436.45
92-96, SI, HHS5008, $436.45
92-96, VTEC, HHS5009, $436.45
97-99, Type SH, HHS5014, $436.45
97-99, HHS5015, $436.45
Max-Air Filter System:
92-96, S, SI, VTEC, AAF5003, $76.45
97-99, All, AAF5007, $76.45
Direct Air Charger (DAC):
92-96, S, SI, VTEC, DAC5003, $179.95
97-99, All, DAC5007, $179.95
Polished Stainless Steel Cat-Back Exhaust System:
92-96, S, SI, VTEC, HCS7009, $539.95
97-99, Type SH, HCS7022, $539.95
97-99, HCS7023, $539.95
Front Upper Strut Bar:
92-96, S, SI, VTEC, HTA3005, $161.95
97-99, HTA3009, $161.95
Rear Upper Strut Bar:
92-96, S, SI, VTEC, HTA3011, $161.95
97-99, HTA3014, $161.95
Rear Lower Strut Bar:
92-99, S, SI, VTEC, HTB3005, $121.45
Short Shifter Adapter:
92-96, SSA5004, $80.95
97-99, SSA5005, $80.95
Eagle Rods:
93-01, H22, CRS5630H3D, $375 a set
Eibach:
Pro-Kit Springs:
83-87, -1.3", 4001.140, $213.79
88-91, -1.5", 4008.140, $213.79
92-96, -1.2/1.0", 4016.140, $213.79
97-01, -1.3", 4035.140, $228.09
(Type SH will drop more than base model do to lower spring perches on factory struts)
Sport Line Spring Set:
92-96, -1.7/1.5", 4.1640, $213.79
Pro-Control Bars: **** NO LONGER AVAILABLE ****
Alignment Kits (+/-1.5deg):
97-01, Rear, 5.84945K, $132.28
92-96, Front, 5.84945K, $132.28
92-96, Rear, 5.84945K, $132.28
Energy Suspension Bushings:
92-96
Front End Control Arm Bushing Set, 16-3106, $41.54
Rear End Control Arm Bushing Set, 16-3112, $28.04
Front Strut Rod Bushing Set, 16-7103, $17.35
Front Sway Bar Frame Bushings, 16-5121, 6.77
Rear Sway Bar Frame Bushings, 16-5122, $17.35
Rear Trailing Arm Bushing Set, 16-7105, $43.16
92-98
Front Coil Spring Isolator Set, 16-6101, $12.42
Rear Coil Spring Isolator Set, 16-6103, $9.79
Front Bump Stop Set, 16-9101, $7.88
Rear Bump Stop Set, 16-9102, $6.77
Front Shock Upper & lower Bushing Set, 16-8106, $17.35
Rear Shock Upper & lower Bushing Set, 16-8108, $24.91
Hyper-Flex System:
92-96
16-18106, $145.17
Includes: front and rear control arm bushings, front strut
rod bushings, front and rear coil spring isolators, front
and rear bump stops, and front and rear shock bushings
Ferrea:
Special Alloy Valves:
93-01, H22, 30mm (stock), F1823P,
93-01, H22, 30.5mm (+.5), F1958P,
93-01, H22, 31mm (+1mm), F1458P,
Competition Plus Valves:
93-01, H22, 30mm (stock), F1824P,
93-01, H22, 30.5mm (+.5), F1956P,
93-01, H22, 31mm (+1mm), F1456P,
Roller Rocker System: (this eliminates VTEC)
93-01, H22, Aluminum-Magnesium, RR1001,
Dual Valve Spring:
93-01, H22, Special alloy(turbo), S10026,
93-01, H22, High pressure alloy, S10027,
93-01, H22, Drag racing alloy, S10032,
93-01, H22, Chrome Silicon, S10035,
(requires E11000(titanium) or E10018(aluminum magnesium) retainers)
(must discard OEM spring seats for Ferrea's)
Dual Vavle Spring Kit:
93-01, H22, IC1004,
(Contains S10026, E11005, SL1002, K10035 (vavle locks))
Fidanza Lightweight Aluminum Flywheel:
2.2L & 2.3L, 191221, $371.00
2.2L & 2.3L, 7.25" clutch, 191227, $371.00
Goodridge Stainless Steel Brake Lines:
88-89, S model, 20031, $104.36
88-89, SE & Si, 20032, $104.36
90, S model, 20033, $104.36
90, Si model, 20034, $104.36
91, All, 20035, $104.36
92-96, All, 20036, $104.36
97-01, Base, 20037, $104.36
97-01, Type SH, 20038, $104.36
GReddy EVO Exhaust System:
97+ S/SH, (60-70mm Pipe 115mm Tip), 10156620, $553.52
GReddy Power Extreme Exhaust System:
92-96, VTEC, (60mm Pipe 101mm Tip), 10156020, $550.00
GReddy SP (Street Performance) Exhaust System: (60mm Pipe)
97+, S/SH, (130mm Tip), 10155641, $519.20
92-96, VTEC, (100 X 110 Tip), 10155640, $519.20
GReddy Street Legal Haeaders:
93-96 Si 2.2L, TD05H-18G, 10551020, $430.32
GReddy Timing Belt:
H22A, 13554504, $130.24
GReddy Balancer Belt:
H22A, 13554505, $52.80
Ground Control Coilover Kit:
Your choice of spring rates--you set the ride height!
88-91, $339 per set
92-01 , $339 per set
H&R Sport Springs:
88-91, 1.75" drop, 51874, $182.33
92-96, 1.3" drop, 29879, $182.33
97-up, 1.4" drop, 29879.2, $182.33
Other models available, email for prices
HKS:
B16/B17/B18/B20, 2203-RH004, $171.60
ZC, 2203-RH002, $162.80
Dragger Exhaust System:
97-99, Base Model, 106mm Tip/60mm Pipe, 3302-EX039, $673.20
Sport Exhaust System:
92-96, Si non-vtec, 96mm Tip/60mm Pipe, LES-H13, $448.80
Super Mega Flow Intake System:
97-99, 1504-SH04US, $132.00
92-96, 1504-SH007, $158.40
Hotshot Headers:
92-98, Vtec Race Only Header, HD3070, (Does not Bolt to Exhaust) $448.80
Hotshot Intakes:
96-01, HD4067, $83.46
Ingalls Camber Adjustment Kits:
83-87, Front, -1 to +3 degrees, 35640, $44.50 per wheel
88-91, Front & Rear, -1 to +3 degrees, 35650, $44.50 per wheel
92-96, Front & Rear, +1-1/4 to +3 degrees, 35720, $91.78 per wheel
97-01, Front, +1-3/4 to +4 degrees, 35580, $140.88 per wheel
97-01, Rear, +1-1/4 to +3 degrees, 35720, $91.78 per wheel
** Other sizes available, email or call for details **
inTrax Lowering Springs:
83-87, -1.7"(F & R), 35.1.010, $201.75
88-91, Incl. AWS, -1.7"(F & R), 35.1.011, $201.75
92-96, Incl. AWS, -2"(F), -1.9"(R), 35.1.012, $201.75
97+ Incl. SH, -2"(F), -1.9"(R), 35.1.013, $201.75
JE Pistons: (Prices are per piston. You need four of everything)
92-96, H23, 9:1, .020, 165051, $138.45
92-96, H23, 10:1, .020, 165054, $138.45
92-96, H23, rings, C001-3445, $86.23
92-01, H22, 9:1, STD, 165052, $138.45
92-01, H22, 10:1, STD, 166036, $138.45
92-01, H22, 11.5:1, STD, 166035, $138.45
92-01, H22, rings, JC0004-3425, $86.23
K&N Filtercharger Air Filter:
80-82, E-2790, $36.14
83-87, E-2925, $42.43
88-91, E-2425, $50.32
85-87, 33-2521, $36.59
92-99, 33-2090, $41.58
Koni Adjustable Suspension
92-96, Front, 8041-1154 Sport*, $144.54 ea
92-96, Rear, 8041-1155 Sport*, $144.54 ea
97-99, Front, 8041-1232 Sport*, $144.54 ea
97-99, Rear, 8041-1155 Sport*, $144.54 ea
*Features adjustable spring seat for ride height adjustment
(only with the springs off)
KVR Performance Carbon Fiber Semi-Metallic Brake Pads:
79-81, All, Front, M7103, $38.79
1982, All , Front, M7132, $
83-87, All, Front, M7162, $44.11
84-87, w/Carb&Rear Discs, Rear, M7180, $122.44
85-87, w/ FI, Front, M7229, $38.79
88-90, w/o FI, Front, M7263, $
88-91, w/ FI, Front, M7235, $55.52
85-91, All, Rear , M7443, $44.11
92-96, Si, Front, M7448, $59.32
93-96, VTEC, Front, M7382, $59.32
92-96, All, Rear , M7256, $55.52
97-01, All, Front, M7382, $59.32
97-01, Rear , M7418, $55.52
KVR Performance Cross-Drilled or Slotted Rotors:
79-82, All, Front, HO509, $58.50
83-87, All, Front, HO517, $63.90
84-87, All, Rear, HO518, $68.40
85-90, All, Front, HO516, $63.90
88-91, All, Rear, HO524, $68.40
88-91, w/ FI, Front, HO522, $72.90
92-96, Si, Front, HO531, $80.10
93-96, VTEC, Front, HO532, $100.80
92-96, All, Rear , HO553, $88.20
97-01, All, Front, HO558, $90.00
97-01, Rear , HO567, $99.00
(All prices for single rotor)
KVR Python Calipers (Loaded w/KVR Carbon-Fiber Pads):
93-96 w/VTEC, Front, HC532, $495 ea
KVR Big Brake Kits 12.4" & 13" available for 92-01
KYB AGX Adjustable Shock Absorber:
92-01, All, Left Front, 741031, $91.18
92-01, All, Right Front, 741030, $91.18
92-01, All, Rear, 741032, $91.18
Magnecor KV85 Competition Ignition Wires:
97-00 Prelude, SR, SH, 45188, $77.13
93-96 VTEC 2.2L DOHC, 45188, $77.13
92-96 Si SE & SR, 45172, $71.65
92-96 S 2.2L SOHC, 45171, $71.87
88-91 Si SE & SR, 45162, $67.74
88-90 S, 45131, $46.71
83-87, 45159, $56.73
79-82, 4530, $55.19
Neuspeed:
Front Strut Tower Bars:
92-96, w/o VTEC, Black, 35.20.80,
92-96, w/ VTEC, Black, 35.20.81,
97-01, All, 35.20.82,
(Add P to end of part number for Chrome/Aluminum)
Sway Bars:
92-96, All, 1", Front, 15.20.25.1,
1997, All, 1", Front, 15.20.25.2,
98-01, All, 1", Front, 15.20.25.3,
92-01, All, 1", Rear, 25.20.25,
N2 Headers:
92-96, Si, 88.20.84,
92-96, VTEC, 88.20.22,
97-01, Base, 88.20.94,
97-01, Type SH, 88.20.86,
Short Shift Adapter:
92-96, All, 66.20.64,
97-01, All, 66.20.94,
Plug Wire Set:
88-91, 2.0L, 47.20.84,
92-96, F22&H23, 47.20.16,
92-96, H22, 47.20.64,
97-01, All, 47.20.94,
NGK Iridium Plugs: (min 4 plugs)
85-86, BT, 2115, $6.40 each
87, A20A3, 2115, $6.40 each
88-6/90, B20A5, 4919, $6.40 each
7/90-91, B20A5 & B21A1, 2477, $6.40 each
92-01, H22A & H23A, 6441, $6.40 each
PaceSetter Monza Exhaust System:
97-99 2.2L VTEC, 88-1421, $228.76
92-93 S/Si, 88-1418, $196.59
90-91 SE/Si, 88-1346, $185.86
88-89 SE/Si, 88-1347, $185.86
85-87 Si, 88-1417, $178.71
PaceSetter Armor Coat Header:
97-99 2.2L VTEC, 72C1247, $260.94
92-95 Si, 72C1244, $253.79
92-95 S, 72C1243, $253.79
90-91 Si, 72C1242, $253.79
88-90 Si, 72C1241, $253.79
85-87 Si, 72C1250, $264.51
PaceSetter Black Paint Header:
97-99 2.2L VTEC, 70-1247, $171.56
92-95 Si, 70-1244, $164.41
92-95 S, 70-1243. $164.41
90-91 Si, 70-1242, $164.41
88-90 Si, 70-1241, $164.41
85-87 Si, 70-1250, $175.14
PaceSetter Quik-Shift Adjustable Throw Shifter:
83-87, 01-0250, $64.32
Perma-Cool Engine Oil & Transmission Cooling Products:
Universal Engine Oil Cooler Kits:
150 HP 3/4"x7-1/2"x12-1/2" Remote Style, 69195, $92.12
150 HP 3/4"x7-1/2"x12-1/2" Sandwich Style, 69189, $85.44
250 HP 1-1/2"x7"x14", Remote Style, 10195, $110.62
250 HP 1-1/2"x7"x14", Sandwich Style, 10189, $104.10
450 HP 1-1/2"x7"x21", Remote Style, 40195, $181.64
450 HP 1-1/2"x7"x21", Sandwich Style, 40189, $187.38
Oil Cooler Kit Accessories:
Trans Remote Mount Kit, 102, $7.73
Metal Mounting Kit, 103, $3.98
Nylon Tie Mounting Kit, 105, $3.75
Temp Gauge Kit, 15106, $53.50
Oil Filter Relocation Kits:
Single Oil Filter, 10695, $47.32
Dual Oil Filter, 10795, $62.59
Automatic Trans Filter Kits:
Standard Kit w/Filter 10678, $38.90
Deluxe Kit w/Filter & Gauge 10677, $79.31
Turbo Flex High Performance Electric Fans: (Reversible Push/Pull)
10" Fan, Mounting Area 13"x10-1/2"x2-1/2", 19010, $92.84
12" Fan, Mounting Area 12-1/2"x12-1/2"x3-3/4", 19008, $105.18
14" Fan, Mounting Area 14"x14"x3-3/4", 19114, $120.79
16" Fan, Mounting Area 16"x16"x3-3/4", 19115, $127.15
18" Fan, Mounting Area 17-3/4"x17-3/4"x3-3/4", 19117, $140.23
Turbo Flex Electric Fan Accessories:
Wiring Kit w/170 Degree Thermal Switch, 19001, $19.56
Electric Fan Wiring Kit, Adjustable (Probe), 18905, $55.08
Metal Mounting Kit, 104, $4.06
30 Amp A/C Relay, 19002, $8.33
ProPod Gauge Pods:
97-00, Dual 2 1/16", 82135, $26.74
RPS Clutches:
Sport Series:
92-01, Street Disc, (220ft/lbs), SS-01908-ST, $292.50
92-01, Solid Hub, (280ft/lbs), SS-01908-SH, $328.50
92-01, Sprung Hub, (280ft/lbs), SS-01908-SP, $346.50
Max Series:
92-01, Street Disc, (282ft/lbs), MS-01908-ST, $378.90
92-01, Solid Hub, (390ft/lbs), MS-01908-SH, $396.90
92-01, Sprung Hub, (390ft/lbs), MS-01908-SP, $432.90
Carbon Claw:
92-01, Single Disc, (475fl/lbs), CC-01908-SG, $1345.50
SCE Pro-Copper Head Gaskets:
.8128mm, 91413, $48.04
1.0922mm, 91414, $48.04
1.27mm, 91415, $56.17
1.5748mm, 91416, $67.10
2.032mm, 91418, $76.66
2.3622mm, 91419, $86.72
** Above Gaskets are for H23A Engine.
.032", 91403, $48.04
.043", 91404, $48.04
.050", 91405, $56.17
.062", 91406, $67.10
.080", 91408, $76.66
.093", 91409, $86.72
**Above Gaskets are for H22A Engine.
SI Swirl-Polished Performance Valves:(prices not current)
2.2 DOHC VTec, Intake, 35.6mm, 14711-PR8000H, $12.99 ea
2.2 DOHC VTec, Exhaust, 30.7mm, 14721-PR8000H, $12.99 ea
2.2 SOHC, Intake, 34mm, 14711-PT3A00H, $12.99 ea
2.2 SOHC, Exhaust, 29mm, 14721-POJA00H, $12.99 ea
Suspension Techniques:
Anti-Sway Bars:
92-96, Front, All (exc. 4WS), 50185, $137.45
92-96, Rear, All (exc. 4WS), 51170, $137.45
97-01, Front, All, 50187, $137.45
97-01, Rear, All, 51170, $137.45
Anti-Sway Bar Kit:
92-96, All (exc. 4WS), 52190, $261.15
97-02, All, 52192, $261.15
Sport Lowering Spring Set(-1"):
83-87, 60315, $175.67
88-91, 60320, $175.67
92-96, 60325, $190.37
Techna-Fit Stainless Steel Brake Lines:
88-89, HN-1390, $103.50
89-91, HN-1400, $103.50
92-96, All, HN-1410, $103.50
97, HN-1420, $103.50, $103.50
98, Base, HN-1431, $103.50
98, Type SH, HN-1430, $103.50
Available in red, yellow, blue, and clear
Tokico Performance:
Performance Struts:
83-87.5, Front, HU2689, $56.13
83-87.5, Rear, HB2046*, $89.82
83-87.5, Rear, HB2047*, $89.82
87.5-91, Front, HU2822, $65.96
87.5-91, Front, HU2823, $65.96
87.5-91, Rear, HU2824, $60.34
87.5-91, Rear, HU2825, $60.34
92-01, exc. SH, Front, HU3557, $75.08
92-01, exc. SH, Front, HU3558, $75.08
92-01, exc. SH, Rear, HU3559, $72.96
* Brakeline bracket may vary on OE units
Illumina Adjustable Struts:
92-01, exc. SH, Front, BU3557, $116.50
92-01, exc. SH, Front, BU3558, $116.50
92-01, exc. SH, Rear, BU3559, $116.50
Advanced Handling Lowering Springs:
87.5-91, -1", HPS5047, $188.84
92-00, -1.5", HPS5041, $188.84
Advanced Handling Suspension Kit:
87-91, HPK223, $375.20
92-00, HPK233, $412.20
Illumina Advanced Handling Suspension Kit:
92-00, ILK234, $556.60
Unorthdox Racing Ultra S- Lightened Underdrive Crank Pulley:
92, 2.2L/2.3L SOHC/DOHC 16V ALL, 0206102xx, $177.65
93-96, 2.2L SOHC 16V, 0206102xx, $177.65
93-96, 2.3L DOHC 16V, 0206102xx, $177.65
93-00, 2.2L DOHC 16V, 0206104, $191.25
88-91, 2.0L SOHC/DOHC 16V, 0206107xx, $177.65
90-91, 2.1 SOHC/DOHC 16V, 0206107xx, $177.65
(xx: 01- Black, 02- Clear, 03- Red, 04- Blue)
Wiseco Stock-Shelf (non-custom) Forged Aluminum Pistons
H-22 VTec, $446.60 per set
(please specify 87,88,89mm sizes when ordering)
ACT Clutches:
Racing Disc:
83-87, 1.8L, 6P200K
84-87, 2.0L, 6P212K
88-89, 2.0L, 6P212L
90-91, 2.0L, 6P220J
92-01, All, 6P224J
83-87, 1.8L, 4P200K
84-87, 2.0L, 4P212K
88-89, 2.0L, 4P212L
90-91, 2.0L, 4P220J
92-01, All, 4P224J
Release Bearing:
Air Bypass Valve:
Cold Air Induction:
O.E. Caliper Kit:
401-A907, $395.10
A'PEXi VTEC AFC
401-A908, $413.10
405-A012, $247.50
430-A006, $14.35
A'PEXi WS Exhaust:
A'PEXi N1 Exhaust:
ARP Fastners:
Pillar Gauge Pods:
45063, $98.33
Centerforce:
Centerforce I:
Centerforce II:
6000-6420, $202.22
730-0091, $47.79
730-0092, $68.15
Crower Rods:
$214.95
Eagle Rods:
Eibach:
Pro-Kit Springs:
92-96
92-98
Hyper-Flex System:
92-96
16-18106, $145.17
Ferrea:
Dual Valve Spring:
93-01, H22, IC1004,
GReddy Timing Belt:
88-91, $339 per set
H&R Sport Springs:
HKS:
Hotshot Headers:
Hotshot Intakes:
79-82, 4530, $55.19
Neuspeed:
Sway Bars:
N2 Headers:
Plug Wire Set:
ProPod Gauge Pods:
RPS Clutches:
Sport Series:
Max Series:
Carbon Claw:
Anti-Sway Bars:
Anti-Sway Bar Kit:
Tokico Performance:
Performance Struts:
