CEL Codes and How to Check
Posted: Tue Nov 22, 2005 12:40 am
What are ECU problem codes, also called CEL codes? *CEL = Check Engine Light.
ECU problems codes are diagnostic outputs from the ECU, used to indicate in what area a problem lies. Usually the check engine warning light comes on for a serious problem, but will not necessarily come on for a minor problem. The ECU will remember problem codes even with the ignition off; and the only way to clear the codes is to disconnect the battery or remove the hazard fuse for half a minute or so.
How to read ECU codes?
Find the diagnostic connector, which is a two wire blue/grey/green connector found near the passengers feet, or in the center console (Each car may differ) Click link for image of connector and paperclip jumper:
http://home.mindspring.com/~redracer95/stuff/id24.html
Short out the diagnostic connector with a piece of wire, e.g. a paper clip bent to a U-shape, etc. To read the codes, turn the ignition on.
The check engine light on the dash will flash the problem codes. If there is more than 1 problem, a different code will subsequently follow the first after a brief pause.
There are two types of flashes - short and long, which are combined to represent number codes. Each short flash indicates 1 unit and each long flash represents 10 units. Problem codes 1 - 9 are indicated by 1 - 9 flashes, problem codes 10 - 90 use 1 - 9 long flashes. If the code is more than 9, the long flashes will start first before the short ones. The codes will continue to repeat as long as your ignition is on.
Code and Meaning
1 "Oxygen Sensor ""A"" (Primary)"
defective circuit or unplugged / defective sensor
2 "Oxygen Sensor ""B"""
3 MAP Sensor (Manifold Absolute Pressure)
4 CKP Sensor (Crankshaft Position Sensor)
5 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
6 ECT Sensor (Engine Coolant Temperature)
7 TP Sensor (Throttle Position)
8 TDC Sensor (Top Dead Center)
9 CYP Sensor (Cylinder)
10 IAT Sensor (Intake Air Temperature)
12 EGR Lift Sensor (Exhaust Gas Recirculation)
13 BARO Sensor (Atmospheric Pressure)
14 IAC Valve (Idle Air Control)
15 Ignition Output Signal missing or defective ignition output signal
16 Fuel Injector System defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19 Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector defective circuit or unplugged
/defective sensor
21 VTEC Solenoid Valve defective circuit or unplugged
/defective solenoid valve
22 VTEC Oil Pressure Switch defective circuit or unplugged
/defective oil pressure switch
23 KS (Knock Sensor) defective circuit or unplugged / defective sensor
30 "Automatic Transmission Signal: ""A"" / SEAF / SEFA / TMA or TMB" defective circuit or unplugged / defective sensor
31 "Automatic Transmission Signal ""B""" defective circuit or unplugged / defective sensor
41 Primary Oxygen Sensor - Heater circuit malfunction
43 Fuel Supply System defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
48 LAF Sensor (Lean Air Fuel) defective circuit or unplugged
/defective sensor
54 CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
58 TDC Sensor 2 (Top Dead Center) defective circuit or unplugged
/defective sensor
61 "Oxygen Sensor, Heated - Sensor 1 (Primary)"
"high voltage, low voltage, or slow response"
63 "Oxygen Sensor, Heated - Sensor 2 (Secondary)"
65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70 Automatic Transmission malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
75 Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
76 Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80 Exhaust Gas Recirculation insufficient flow detected
76 ECT Sensor (Engine Coolant Temperature) circuit range
/performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow[/img]
Code and Meaning
/defective sensor
/defective sensor
/defective sensor
