Suspension drop info!
mpL
Prelude Model: 1991 SE
Postby mpL » Tue Aug 06, 2013 8:06 pm
Hi,
I would like to drop my car a little bit and I had some questions. Which part exactly I need to change? Which brand I should buy? How low can I go to do not domage the car!?
Re: Suspension drop info!
Postby spiffyguido » Tue Aug 06, 2013 9:43 pm
If you just want to lower the car, you just need new springs. However, if you want to really make the car handle better at the same time, you really need to pair the new springs with a set of matched struts. Lowering springs will usually blow the stock struts out in short order because of he increased spring rate.
The maximum drop really depends on your wheel size and how practical you want the car to be. I have a 0.75" drop on 14 inch wheels and I don't think I'd want to go lower. On most Hondas, drops of up to 1.5" are usually okay. Past that point you start having issues with camber and irregular tire wear.
There are lots of good brands. I have Tokico struts and springs. Very good.
Eibach makes good springs. KYB makes good stuts. Koni is also very good. Neuspeed used to make a set of lowering springs for the Prelude that were good, but I think they've been discontinued. HotBits makes great stuff, but again, I'm not sure they make a set for the 3rd gen. Tein makes good stuff as well.
A lot of people will just choose to get a set of Ground Control coilovers (which are good) and pair them with a set of Koni Yellows. This is a relatively inexpensive way to get your car lower and greatly improve the strut set.
mpL
Postby mpL » Sun Aug 11, 2013 8:26 pm
spiffyguido wrote:If you just want to lower the car, you just need new springs. However, if you want to really make the car handle better at the same time, you really need to pair the new springs with a set of matched struts. Lowering springs will usually blow the stock struts out in short order because of he increased spring rate.
I want my car to handle better so what would be the best combinaison(brands) and how much did you pay for your tokico? Thanks
Postby spiffyguido » Mon Aug 12, 2013 7:41 am
Can't recall what I paid for the Tokicos. It was around $350 I think.
Can't speak for any other brands, but the Tokicos have been excellent. They did a lot to improve handling.
mpL
Postby mpL » Mon Aug 12, 2013 9:05 pm
spiffyguido wrote:Can't recall what I paid for the Tokicos. It was around $350 I think.
Thanks dude ! And do you know where can I buy tokico for my prelude?
Postby spiffyguido » Tue Aug 13, 2013 8:08 am
The 3rd gen kit is HPK223. It's available for sale right now on Amazon:
Tokico HPK223 HP Suspension Kit for Honda Prelude
Alternatively, you can Google other vendors.
Users browsing this forum: No registered users and 3 guests
