a/c compressor
91darkness
Prelude Guru
a/c compressor
Post by 91darkness »
I decided to mess with my a/c, since it hasnt worked pretty much since i had the car. I bought a can of some stop leak/uv dye just to test it. Well as soon as the dye went in it shot out the compressor through what looks like a valve. The valve faces directly to the side of the header. I tried to look up what this is and couldnt find a good picture of it or discription. Any clue?
Re: a/c compressor
I think I know the one you mean. Does it look like a tire valve? There are points on the A/C lines where they can be filled.
91darkness
Prelude Guru
Re: a/c compressor
here is a pic of the compressor facing the header(facing passenger side from front of car). This is where the dye shot out of.
Re: a/c compressor
Is that a hole in the center of the bolt?
91darkness
Prelude Guru
Re: a/c compressor
yes there is a hole.
Re: a/c compressor
There must be some sort of check valve integrated into that bolt.
Is it identified in the following schematic:
http://www.hondaautomotiveparts.com/aut ... )+(2.0+SI)
prelude95
Re: a/c compressor
Post by prelude95 »
it does sound like a pressure releafe valve.thats kick of when the compressor is building up too much pressure, it could be a cause of diffrent problem. for example ur orphase tube could be stuck or the eveperator not working propertly.
91darkness
Prelude Guru
Re: a/c compressor
thanks guys, i know a guy who can test my system properly without killing my wallet. We will see what happens.
91darkness
Prelude Guru
Re: a/c compressor
Since some AC stuff has been popping up. A mechanic told me my AC compressor is shot.
Re: a/c compressor
That blows!
Time to source a replacement one from a wrecker. Just be glad this didn't happen before the onset of summer.
Circlejerk
Re: a/c compressor
Post by Circlejerk »
I may have two extra compressors. Let me know...and No, I don't have a clue if they are any good or not....But free is always a good price....
91darkness
Prelude Guru
Re: a/c compressor
Im up for free, just tell me how much shipping would be, thanks
