Reverse lights
Reverse lights
Well, the reverse lights just don't go on when it is in reverse. The bulbs are good and the car is stick. I was thinking it could be the switch, does that sound right or do you have any other suggestions?
Re: Reverse lights
Where exactly is the switch located?
Re: Reverse lights
Not the most familiar with 3rd gens -- but I believe it is on the top of your transmission. Download the manual (top of the page under manuals, click, scroll down to 3rd gen, first manual option) and look through. Section 7 has the info on the transaxle. Page through it to the piece on back up light switch, then in Section 16 you will find the schematic for the back up lights and how to test if they're working or not.
Look on your transmission, top or bottom, it will be the ONLY two electrical wires coming out of the transmission. I've included the cut image of the switch from Section 7 in the manual and where on the trans you can look to find it. Dig through the manual and see what you can learn, but if you get stuck, come back, we're always here to help out when needed.
(assuming yours is a manual trans but I don't think it matters in regard to the switch location or use)
