by mludeman » Fri Mar 08, 2013 10:24 am
Update: Tore into my car again, starting with pulling fuses which made not change. Unplugged multiswitch for lights and wiper washer no change here either. Also pulled signal flasher hazard box with no change. Car is disassembled from front bumper to exposure of most of the wires to the rear. What I have found is that I'm getting voltage of 10 plus volts through the right hand front signal socket and about 1 volt less on the left with no lights or switches on. As with all electrical the higher the volts the closer you are to the problem ( an assumption on my part), hopefully. Color code on the wire is grn/ylw stripe. I did reverse the polarity with the multimeter to make sure which wire had the positive charge. I'm heading back to the shop for another day of searching. Anyone with any ideas?
