[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 561: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 617: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 494: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5312: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
Honda Prelude Forum - PreludeDriver.com • 11991 Staites SI Prelude Throttle Position Sensor
Posted: Tue Feb 19, 2013 4:50 pm
by jayped
Greetings to all Prelude Fans from a Newbie.
Has anyone any idea where I can obtain an exact replacement throttle position sensor for the Staites SI Prelude
It is a 1991 model with limited slip Diff, ABS brakes and climate control. The track on the existing one has developed a hole that produces some erratic throttle response.
Bert
Re: 11991 Staites SI Prelude Throttle Position Sensor
Posted: Wed Feb 20, 2013 12:51 pm
As the TPS sensor is fastened (usually permanently) to the throttle body on these cars, it might be easiest to just find a throttle body on eBay and swap it out.
The throttle body on your car should be the same as most other 3rd gens.
Would love to see pics of your car. The SI States edition is very rare.
